2013 outlander max xt 650 loud whirring noise
By Cj Winds
By KIWINZ
Hello
My son scored a free Moto4 - late 80s from the looks of it. I don't know anything else about its history as the owner wasn't there when i picked it up. Can't see the VIN number as its a bit rusty. He cleaned the carb and then with some either it started and still starts first pull. Its runs really nice - not rattles etc. Goes forwards well and the brakes work fine so it looks like a keeper, However, we have only managed to get it into reverse once.
1) it won't shift down into what seems like where first would be - 2nd and upwards only. The changes between gears is fine. No crunching or missed gears - just no first gear. 2nd gears appears to be as low as it will go
2) the clutch - when you hold the gear lever up or down works (only the second ATV we have had. Other is a Quadrunner which doesn't have this feature)
3) no neutral light - will start when no in neutral - should it do that?
4) the one time we did get it into reverse the neutral and then the red (reverse) lights worked. Swapped easy between forward and reverse - when it went into second, it didn't return to first or neutral
5) checked the clutch adjust on the RHS - seemed fine to me. When i turned the screw back 1/8 it was where it was to start with. Clutch doesn't slip. The bike will move forward is all gears.
Any help would be appreciated
Andrew
By jeffrocdx
By wilmpie
hi everybody
I have a kymco mxu 250 automatic from 2006 250 cc that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
if i shutdown the motor and push the quad and restart then its in neutral and don't go forwards or backwards, i already checkt if my motor is running good stationairy .
what can it be or what can i do to fix this?
thanx in advance
p.s. Sorry for my bad english it's not my first language.
By BruinBeater
Hey all, BruinBeater here. Just joined up from the Pittsburgh, PA area.
Got a Polaris Sportsman 1000 and a 570 in the garage that don't get ridden quite enough but looking forward to a family trip this fall.
I'm the unofficial mechanic of the extended family. In the past month or so I've replaced a transmission in a Chevy Silverado, rust repair on a Chevy Malibu, electrical repair on a Subaru Crosstrek, overheating issue solved on a Can Am Commander, and right now I have a pair of Grizzly and a Bruin 350 in the garage. Both have a no start condition and have been sitting for 2+ years.
