By Ironworker709
I recently got a great deal on a 2001 Big Bear 400 4x4.it sat in a barn for 2 years while the guy was in college,so it need carb work...got it to use around the property,not racing or anything crazy with it
It runs GREAT and strong..no smoke or funny noises,just seems to have an issue at times ,when you hit the throttle it want's to die ,most of the time it runs strong.
So am debating a rebuild kit or new oem carb...i got to looking around really good yesterday and found this broke off..( the bent tube where the pencil is pointing).... is this a part that comes with a new carb?..if not,,where can i get the part?
I found a diagram online but it does not show the bent tube with a nut on it but says it a "Starter set" in the diagram(Number 21 in the diagram)
I checked the petcock and it is getting plenty of fuel flow..but it has the common drip leak..so i am ordering a new one,..was going to get the seal kit but for the price it is about the same price as a whole new petcock
Just trying to figure out where i can get this part for repair
By texasgator41
i have a 2021 4wheeler and i just wrecked it, but i don’t have insurance on it. repairs are going to be in the thousands. is it possible that i can put it in the insurance and make a claim in a timely manner? i know it’s a wicked thing to do but i need help.
By Alan Callison
OK ya'll, How do I fix this problem? The plastic part holding the cable in the carb snapped and the spring is slipping out causing a really hi idle speed. I pushed it bacl kin dropping the idle so how can I fix it. I know I can get a kkit but I dont know how to do it. Any help would be appreciated. Thanks.
By QuadConfussion
Hey everyone! Just introducing myself and hoping I can get some insight on where to start. I have an older quad, my guess is about an 07. I know it’s a 700 but I’m having some stalling issues with it after it runs for about ten minutes it will die out. It will start right back up and run but after a minute or two it will die again. Any suggestions on where to start checking things?
