hi all ! can some tell me how is 500 ho atv limited to 14kw ,or 19 hp in Europe models , is whole carburetor different ,smaller or is there some other things that limit power.
thank you !:realmad:
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
      Hello there
    • By Adamb2025
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
      Don’t wait—MotoSport’s exclusive deals on genuine OEM parts won’t last. Upgrade your ride and save big on top brands like Honda, Yamaha, and KTM.
      Shop Now
