Similar Tagged Content
By Ellery Zandt
Does anyone have a redcat 250 or falcon 250cc that they can share where the two vacuum lines on the carburetor that you run antifreeze through I honestly have no idea where the lines are suppose to go to circulate the antifreeze.
Any help is greatly appreciated.
By BosoxBruce
Recently I noticed gas leaking from under the gas tank on my 2005 250 2x4. As I looked closer it appears to be leaking from the shut off valve under the tank. It's the valve with the handle that can be turned to open, close or reserve. Can this part be replaced? Thank you.
By Derick Joel Smith Trimmings
Buying a Baja 250 tomorrow for 600 bucks, needs nothing but a wheel bearing, i already know Baja is an off brand crappier. Manufacturer, but does anyone have any tips or knowledge of these bikes?
By fatfarmboy
Just bought (Tue. evening) an '89 Suzuki 250 4wd that has been sitting out the last 5 yrs. It's complete, including the shift knobs, battery cover, and headlights. It has the optional cooling fan on it (probly stuck - didn't check), and the engine isn't locked up. Plastic looks good and isnt cracked. Racks aren't bent up. Shift lever works, the foot brake moves (needs oil - have to pull it up by hand), and there's black oil and no water in the engine sight glass. Guy was asking $125 and gladly took $100 for it. Anxious to get started on bringing it back to life. Been wanting one of these for years. As soon as I can get to it (working on a junky "Jackel" right now - Chinese Yamaha Timberwolf). I'm going to pull the tank off it and clean it, clean & possibly rebuild carb, put in new plug, and a battery, then see what happens. If nothing, will keep going until it runs. Feel free to respond if you want to, I'm mainly just excited and wanted to tell somebody.
By Flanstone
I just bought two 1985 TRX250's from my father-in-law. One runs great, the other not so much. The one is having issues with the shifter. The shifter seems to be resting lower than normal. When I press the shifter downward, it just pops back up. Any thougjts as to what the issue might be?
Similar Topics
By SirMaxwell
Any luck with manuals?
I need a carb in the owrst way and am have gone down a lot of rabbit holes (over 90 tabs and counting). Factory calls for a Mikuni BST34/1 (I think, but need to check manual). I don't care what or who makes the carb, just need a basic reliable carb. No Racing etc, just puttering. I currently only have the cable with the round slide attached.
Don't care if its round if I know what other parts to get to make it all function.
Thanks for help, and listening, gonna go chase more rabbits I guess.
Max
By Edgar5656
Looking for a carb for 87 moto4 200. Just bought the machine and it’s got a Chinese one that’s not working right even after I cleaned it out. Looking for the original mikuni vm22sf.
By Devon400ex
Quad seems to be hitting the rev limiter cutting out at a certain rpm almost like a consistent bog at a certain rpm, have replaced the cdi and continued with the same issue even replaced the carb and the same issue continues help
By Michael Thornton
Why does the 2001 grizzly not have com bearings or something to protect the head.
