    • By joezee13
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
    • By bikeoffer107
      List of the NEW and used MODEL OF Motorcycles or Scooters:
      Piaggio,Marietta,Yamaha,Ducati,Supersport,Honda,KTM and More.
      [email protected]
      Call or WhatsApp: + 1-863-300-3370
      New 2025 Kawasaki Z650 ABS -- $4,400usd
      New 2025 Honda CRF300L -- $3,200usd
      Kawasaki Z900
      Kawasaki Ninja 400
      New 2025 Piaggio BV 400 Scooter Motorcycle
      Used 2023 Piaggio Liberty S50 Scooter Motorcycle
      HONDA CB 500 X
      HONDA CRF450R 2022 FULL STREET LEGAL
      Harley Davidson RH975 2024
      HARLEY DAVIDSON ULTRA GLIDE CLASSIC 1640
      Harley-Davidson Street Glide
      SUZUKI GSX600
      Honda vtx 1800
      YAMAHA RAPTOR 700R
      Yamaha YZF-R7
      KTM 1290
      KTM 690 ENDURO R 2020 SUPER
      CAN AM SPYDER 1000
      supersport 950s sportbike motorcycle
      2021 Ducati 950 supersport 950s sportbike motorcycle
      2024 Ducati panigale supersport 950s sportbike motorcycle
      Yamaha Mt 125-MT15-MT03-MT07-MT09 Motorcycle
      Yamaha R1,R15,R9 motorcycle
      If you wish for any model of brand not included above, then send us your enquiry and order quote and we get in touch with you soonest.
      New/Used,Piaggio,Yamaha,Ducati,supersport,sportbike motorcycle ETC
    • By Ejwill
      I rebuilt the top end on my 2007 Honda Trx500fe. It ran fine right after the rebuilt. But now when I try to crank it it blows Bach through the carburetor. I held my hand over the opening for the intake air and it blew gas back on my hand. Can figure out what happened all of a sudden. It was cranking and was able to ride it running through all the gears. Now can get it to crank just blowing gas back to the air filter. Need help again. Starting to think I should have walked away from this one.
