This is my first post. I've been leaking gas for some time and just figured out from where. It's leaking from what I assume is some sort of overflow hose or something near the bottom right of the carb. Any ideas why and what should be done to fix it?
    • By mehim
    • By LCP92
    • By BillR94
      Thank you for your time
      Bill
