I need a user manual for a 98 King Quad 300 4x4, is there anyway to download one from manufacturer or online somewhere? Not a service manual though that would help another matter. Is the Clymer guide good and is it in digital format? All help appreciated for this newbie with a used 4 wheeler.:wink:
OK thanks, kind f figured that,. I do have a few problems with this machine so will pick your brain if you dont mind. I charged the battery full (according to charger) last night and the starter just clicks like on a car that has a low battery, Im guessing the battery is junk and the other problem is it only runs with the choke on full, if I lower it, it dies, I did work on cars and am good with electrical so what do you think?
i would sand the connections bare again at the solenoid and cables, even running to the starter. it may end up the same thing if your battery is no good, but be right when you replace it. the carb i would run some seafoam through the tank and that might eliminate tearing the carb apart to clean it ...
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
