    • By docdoug72
    • By Atomusthenes
    • By Daleon
      I recently was gifted a 1998 Lakota 300 and it was modified to start only by electric start. ( Removed the pull start) So I put together all the parts he was able to find and I believe it's back together like it's supposed to be but when I start it via electric start, it turns over but I do not hear the sound a proper combustion sound makes. Furthermore, I did all the spark tests and it's showing none whatsoever.
       I installed a new starter and I believe I installed it correctly. Could I have accidentally thrown the timing off? I lined up the timing marks but the top mark will NOT line up correctly.
    • By heath
    • By Joeguy
      So i bought a chinese carb and in messing around still trying to get it to run right i figured id pull the spark plug to see if it was running rich, well it was definitely but also i have a nasty mark on the strap (i think thats what its called) that looks like the piston has been smacking it. I never actually pulled the plug because i had it running for a second on starter fluid when i first bought it and was just stupid and figured whatever was in there was good. The part number on it is DPR7EA, which is similar to what is called out for in the manual but i assume the little bit off that the code is means it must be a bit longer or something. Unless the plugs are made like this, but i can pretty easily see that metal has been pushed away from the area of impact. What are the odds that my piston is trashed now you think? It does still run just not well due to carb issues but thats a whole other problem.
      Actually i just took a second to google both plugs and it says the reach is the same its just different resistor values and gap size, so maybe the bigger gap is why its hitting. Either way the actual one for it is on the way and i hope it just didnt do to much damage. Wish i woulda just went over the whole thing like i normally do with this stuff.
