2012 Can-Am Spyder RT L. Edition ( Western MA)
By jwh
By nberga
Hi,
This weekend went on a trip with my all brand new cforce 1000 touring, went from tarmac to reach the small muddy places and dirt and even sand.
Was running great until tre situations occurred:
First, after putting 50km without problems and still respecting the break in on the engine, we came across a sand small uphill and just turned the 4x4, and almost reaching the top, got a strange loss of traction with a noise like something was slipping, the noise looked to came from the front but cannot give 100% sure it was the differential or not, but something was definitely slipping, also i disconnected the 4x4 and tried to make the uphill only rear traction and almost reaching the top the same noise. I got a friend that was on my old 850XC and it drove pass this small uphill almost at idle.....what do you think??? Belt Slipping, Front differential or Gearbox/CVT?
Second, after this situation, i had the engine light going from on to off on the trail back home, but on the trail back home, i had no issues with temp rising nor noises nor anything, we drove normally, but without sand nor uphills, just rolling normally on dirt roads.
Third, a strange situation, riding on normal mode, i was going at 38 to 40km rolling but the engine was revving on 4000rpm at those speeds, i feel that it was a little bit more reavs than usual for that speed, but this is my perception, what do you think on this???
By gwares
Price : 4500 EUR
The Kymco CV3 is a pioneering three-wheeled maxi-scooter that combines the agility of a motorcycle with the stability of a trike, catering to riders seeking versatility and performance. This can be ridden on a car license!
Key Specifications:
Engine: 550.4 cc parallel-twin, liquid-cooled
Power: 51 bhp (38.1 kW)
Transmission: Continuously Variable Transmission (CVT)
Fuel Tank Capacity: 15.5 litres
Seat Height: 795 mm
Dry Weight: Approximately 280 kg
Brakes: Dual front discs and single rear disc, equipped with ABS
Suspension: Independent front suspension with dual leaning wheels; rear mono-shock
Wheels: Front: 13-inch; Rear: 15-inch
Everything works and new!
We try to capture everything in photos for you.
If you have any questions or need other photos, just ask, thanks.
Send a direct message to make an inquiry or text:
WhatsApp: +33 758 56 21 59
By gwares
Price : 2500 EUR
The Ultra Bee T offers the fastest acceleration of any road-legal electric motorcycle at this price-point, with the flexibility to deal with a wide range of surfaces. With its huge capability the Ultra Bee T will appeal to people looking for a great medium distance commuter, that’s also able to turn its hand to off-road riding and green laning.
By quadcrazy
QUADCRAZY NEEDS YOU!
