Re: help me please
By tflack500tbx
Background,
Any Ideas?
By BillR94
Thank you for your time
Bill
By Matdum
Is there a common trouble to have the connecting rod bearing failure on a 2006 330 polaris magnum ? I have one who have failed and i want to know if there is something to check specifically
thanks a lot !
