Hey guys i just joined today, and i got a quad/atv thats VIN was painted over i got the paint off and the numbers needed to be rubbed back into existance but it seems like i got it, ive tried to run it into multiple searches, but none can pull it up, i was wondering if you guys would happen to know how to decode it. What i really want to know is its Make/Model/Year so i can buy parts for this sucka lol the rims on it were drilled out to fit so it wobbles and barely turns...
heres the VIN please post any results you find.. ill post pictures later when i get to work. (warning THERE ARE NO FENDERS its all bone and motor. with a gas tank)
VIN: RKC5CB0N53A000453
anything will help THNX
Here's the pictures
It looks like a long case GY6 motor. It doesn't have the gy6 engine code tho it's code is NF1 *008831*
No luck. This frame is weird to me also.
    • By Martin82
      Hello to all,
      Im looking for a main wire harness for Polaris sawtooth 200,
      Thanks for info
    • By BillR94
    • By fixitforfree
    • By Matthew Alloway
      What is the best paint for a swing arm. I know powdercoat would be the best, but I am looking for paint type that I can easily do at home.
