By John Sinclair
By mehim
Hi everyone.
By Louznmemind
By kantrud97
Thank you in advance
By Suzukiquad
I have a 97 Yamaha Timberwolf and it is beyond loud, is there any good options to silence them or at least make them bare able to drive. I know it has a crack in the exhaust pipe, but even with that fixed its still loud.
