Hi I have a 300 king quad breaking down when throttled . Starts and idles awe sum only revs up when I turn lights on and eventually blew high beam and then only revved on low which eventually blew .. Now with no lites no revs just idle
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By Adamb2025
    • By BillR94
      Thank you for your time
      Bill
    • By 97kingquad
    • By umax33
      i just got a 1986 honda trx 200 and the reverse and neutral lights don't work, i looked in the service manual and it says to remove two screws and the cover comes up and you can check the bulbs, the book does not show the two screws and i can't see them.Does anyone know how to get to the screws to check the bulbs. i will appreciate any help i can get...thank you
