1985 Honda Odyssey FL350R Service Manual
By umax33
i just got a 1986 honda trx 200 and the reverse and neutral lights don't work, i looked in the service manual and it says to remove two screws and the cover comes up and you can check the bulbs, the book does not show the two screws and i can't see them.Does anyone know how to get to the screws to check the bulbs. i will appreciate any help i can get...thank you
By wanrep
By wanrep
YFZ05YYXH
YF05RH
By Atomusthenes
By Trent Finnessey
