reverse and neutral lights on a 1986 honda trx200
i just got a 1986 honda trx 200 and the reverse and neutral lights don't work, i looked in the service manual and it says to remove two screws and the cover comes up and you can check the bulbs, the book does not show the two screws and i can't see them.Does anyone know how to get to the screws to check the bulbs. i will appreciate any help i can get...thank you
  • Solution
The plastic cover that says honda on it pulls off and the bolts are under there but be carefull not the break the tabs holding the plastic in place. The metal plate is also part of the handlebar mounting clamp.
    • By cavry
      Cavry
    • By Cj Winds
    • By OldATVowner
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
