When trying to start gas spits from air filter side side of carb. If I place my hand over air filter side and leave about 1/8 inch between hand and carb then crank it it will start but runs real bad. I give it throttle and it falls on its face. If I remove my hands it sputters stalls then backfires. It's getting too much gas. I replaced the carburetor​ and nothing has changed. Ive worked on mud trucks but for some reason this tiny little carb has me baffled.
Sent from my Z981 using Tapatalk
    • By realpilot
    • By Elk
      2002 Polaris Magnum 325
    • By OldATVowner
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
