I think maybe someone tried to weld the pedal onto the shaft.
The shifter bottomed out in back, so I couldn't shift out of neutral.  So I loosened it to turn it cc forward, then tightened it as tight as possible.  Now it slips.  Took the floor assembly off in order to get the pedal off the shaft to see the splines but can't slide it off, that's why I'm wondering if it got welded at some point.  Look like it?
    • By OldATVowner
    • By Shorty51
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By jeffrocdx
    • By wilmpie
      hi everybody
      I have a kymco mxu 250 automatic from 2006 250 cc  that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
      if i shutdown the motor and push the quad and restart then its in neutral and don't go forwards or backwards, i already checkt if my motor is running good stationairy .
      what can it be or what can i do to fix this?
      thanx in advance
      p.s. Sorry for my bad english it's not my first language.
