Thanks for the reply. I do have a service manual. It is probably due to my age, but I am having a hard time with the procedure it is listing. Although co-pilot says basically the same thing. I'm going to try to remove it today. Hopefully I will be back on here with what I find.
In case anyone sees my post, I will give a follow up. Removing the transmission drive shaft is quite simple. Since I already had the gears out of the transmission it only took a few minutes. First, I removed the clutch cover, second, I removed the driven clutch off the shaft, third I removed the bearing retainer on the inside of the transmission, and finally the shaft just tapped out.
    • By HTOverland
      We have two 2021 850 XTP MAXX OUTLANDERS with nearly identical VINS. Both ATVS had the DPS error out the exact same week. Repair shop says need new DPS motors. How is that possible? Anyone else have DPS issues?
    • By OldATVowner
    • By tepin
