The race is over and the results are in!
First Place Winner is: Watts16 with 90 Points
-- Grand Prize: Ballance, Borich, Jenks Jerseys. $120 off a set of Fasst Flexx
-- bars, T shirt and stickers.
Second Place Winner is: CT330R with 60 Points
-- $250 Certificate from Rated X Motorsports off a set of long shock
-- A-Arms, T-Shirt and stickers
Third Place Winner is: Hasbeenttduner with 60 Points
-- 3 T-Shirts and stickers
Fourth Place Winner is: Panda with 50 Points
-- GT Thunder T-Shirt, hat & stickers
Fifth Place Winner is: 03GNCC270 with 50 Points.
-- GT Thunder T-Shirt and stickers.
Remember to shoot me an email or PM with your addy to claim your prizes!
You can all finishes here.
Check back in a few days for the new issue of AEM that should be ready to read on Nov 1st. Lots of changes and more great info. Plus the next round of 'Get Madd!' starts up where you can win swag from PowerMadd just for sending us a photo!
    • By TravisCr
      I live in North Eastern Wa, in Collville, and I'm trying to figure out if there are any good regional used parts dealers around here- Our town had a decent Polaris dealer- but dealer prices are what to be expected these days.
      I've got some random little pieces I'm looking for and tired of scrolling ebay (2003 Polaris Sportsman 700)
      These are odds and ends stuff and I'll probably end up on ebay- but figured I'd ask.
    • By rmundell
      We most often go out in our 96 GC, It has a 6" long arm lift kit on 33" tires. V8, front air locker, rear lunchbox locker.
      This way here in AZ we are inside in A/C staying out of the dust!
      We use OnX off road through Android Auto on the double din Pioneer we have fitted it with.
    • By Clifish
      I have looked at a few threads and most are several years old.  I am looking at 2012 Honda rancher that only has a few hundred miles on it but the tires/battery are still original.  I am guessing I will need a new set?  The quad will be used on streets and rocky trails in PA.  Any recommendation for brand, type and place to buy them.  I know Amazon has them but am sometimes leery of what they sell.  How easy to dismount and mount a new set?  Any special tools or just let a shop do it?
    • By Fiend_138
      Where's the best place to look for new/used plastics for older quads?
    • By VikingTrad3r
      I have an 86 yfm250 (moto4 250) i picked up.
      It bogs and pops a bit out the tailpipe if you can even get it higher up in the rpm. It is pretty gutless. I have other 250’s (timberwolves) and its ultra gutless compared to them.
      It has an aftermarket carb on it that has a “W” on it  Its not a mikuni but it looks close
      i figured jetting was off at the high end.
      i had a mimuni that was very crusty, swapped the main jet into the W carb, and the needle, which was set on low slot 4 so left it there.
      it actually ran much better, and cured what i thought was a problem caused by a lean condition from the W carbs main jet being too restricted when i compared to the factory mikuni
      I had it out and was enjoying the upper rpms that i couldnt reach before without bog.  at wot it would fall on its face  low top speed.
      after getting it hot, it would actually refuse to start after dying.
      back to the drawing board.
      when i first got it i adjusted the valves. So i retraced my work and thought maybe id overtightened. double checked, nope all good.  .005 exh , .003 intake, check.
      So i checked the compression.
      here is the trickyness. help me understand this.  I am at 3500ft asl  in calgary canada
      -  initiate test, it goes to 75psi right away. this is low. Even at my elevation im thinking 110psi minimum
      but....this thing starts no problem. even -20c it starts. makes no sense to me. so i press the starter again and it goes to 85. Then i press it again and no change. Then i turn over again and it jumps to 95. Then again...no change. Then again and it goes to 115.  finally finishes at 120 and i cannot get it to go any higher than this.
      ive repeated this multiple times.
      i press and hold the starter...it will max at 75. Then a series of maybe 10 more quick turnovers from the starter and compression inches up to 120psi.
      So, i think the low compression explains the low top end, and even the backfiring out the exhaust when hot. The exhaust is rich enough (incomplete combustion in chamber) and to ignite in the muffler.
      it gets worse when hotter.
      makes me think i have a crack, or something that is low down on the cylinder wall. When the piston stops just above it on the upstroke, and i then turn it over again, it adds pressure to my tester reading.
      thoughts?
