Help. My King Quad 700 will start and idle for about 4minutes then shut off. Have to wait about 20 to 30 minutes before it will start up again, then 4 minutes and die again. I replaced the rectifier and same thing happens. battery is good, holds a charge and rises when throttled up. Any ideas or help would be appreciated.
  • Ajmboy changed the title to 2007 Suzuki King Quad 700 Shuts Off
Yes it is fuel injection and when it shuts off I don’t think the fuel pump is running. If I turn the key switch off and on again I can hear the pump running but it won’t start until it cools down.
my 2005 King 700 will hard quit.  doesn't sputter … die out slowly, its like hitting the kill switch.  After this happens I do occasionally have restart / idling issues.  In my case it settles down after running, so not sure it is the same issue.  A friend of mine said my issue could be related to throttle position sensor which he says could be adjusted by jumping 2 pins on the diag port.  I haven't researched this and haven't done anything about it as I've only run it once since taking ownership later winter.  In my case hitting the kill switch and back on again I can hear my fuel pump.  Is it possible the TPS is "off" sufficiently to cause your issue?  I don't have much else... new to quads as well as my KQ 700
Try the tps look it up on YouTube. If that doesn’t work your injector may be clogged. That’s what mine ended up being. I did the tps thing and it still done it. Took it to a local shop and he found the injector was running on only two ports out of four.
    • By Mister907
    • By Brent Wright
