Create an account
Register a new account
Sign in
Sign In Now
    • By cameronokeefe6
      I have owned my 84 Honda 200m for years now and I am wanting to see what i could do to upgrade horsepower , speed , performance , power etc and do it safely and not cause future harm to the engine.
      I was thinking on getting a 200x piston, will this work and give a good power increase ?  I have heard people have done this in the past and it works great. and i was also thinking on a 200x cam , will the 200x cam fit in this engine and make a difference also does it require the upgrading of any other parts and will i have to run 91 octane instead of 87 ? has anybody run this setup before and got good results ?
      I was also gonna go with a 200x carb but not sure if i have to buy an intake to hook it up or will it just bolt onto the 200m intake and fit fine ?
      If anyone has any suggestions and advice on what i could do it would be greatly appreciated ! thanks in advance.
    • By Bobbles
      New to the forum here, hoping someone can help. I have replaced the cdi, coil and sparkplug yet still no spark. The measurements for the igniter and stator are what they are supposed to be, the kill switch is working as it should, the neutral light is working as well. Any ideas where else to look before i start trying to pull it apart for the stator and igniter?
      Just aquired this Honda 4514. I had heard of them and seen them but had never really looked at one. Amazing machine from the 90s.
      It has a 14 HP inline 2 cylinder engine. A cute little fan like the old school cars had and a little radiator. It has a timing belt on the back of the engine running the cam and a water pump. Just like a miniature car engine with  electronic clutches to turn blades on and off. Pretty hight tech for the 90s not a small thing and built like a tank weighs in at 600 pds hydrostatic trans. I have found out that almost anything you have to do to it the engine has to come out starter timing belt water pump. Very expensive parts i think most got junked for that reason, i did find out they were built by John Deere except for the honda engine.
      Does anyone here have any expierience with these.
    • By p5200
    • By Dumass
