Hey guys im a new member here, names chris and I just paid out the as* to fix my big bear 350. It got rings valve seals a rocker arm a head gasket. I got out yesterday for about an hour before it started to back fire on me and shot a huge black cloud of smoke out. I couldn't get it started so my buddy towed me back to the pick up point and after about an hour of sitting it started up like it was no issue at all. I got my beast back yesterday and have all weekend to get into it. Anything would be great thank you! Note a slight cloud to the left of the photo. Couldn't get one of the thicker smoke
    • By MikeDB
      Greetings to all.  New to the forum, but not to ATVing.  I started when they only had 3 wheels!  Getting back into riding.  Polaris 850.  Too many bells and whistles, but what do you do.  Scouting out places to ride legally now.
    • By junkviking
      Just a quick hello from Atlantic Canada.
    • By LCP92
    • By middlebrookgt
    • By DexKing
