Backcountry Tracks More Spring Track'in - 26 Mar 2019
By DaveswMN
Drove about 100 yards, ran about half throttle wouldn't idle. Put on somenew parts, jug/piston and rings, carb and valve seals.
Thanks for any thoughts.
By Stoopidbot1
I would like to take a second to say happy Father's day to all of the dad's out there... :woot:
By DayBreakJim
20230725_171507.mp4
