  • 8 months later...
Thank You Gwbarm ... glad you enjoyed the video. Thanks for the kind words about my machine, I appreciate it!! I'm lucky I get snow, because I love winter. Mud, not so much ... of course, we don't have a lot here anyway. And what we do have is alkali mud, which eats your machine, or the type that comes up in big clods & dries like cement. No fun to clean off the machine afterwards.
Again, glad you enjoyed the video and I THANK YOU for watching it too!!
Why THANK YOU Little Guy ... glad you enjoyed the video ... and Thank You for watch'in too!!
Yes, the machine is a Great One!! ... And I have a blast on it!!
    • By mikeexplorer
    • By DaveswMN
      Thanks for any thoughts.
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      The Dog loves the runs.
      https://youtu.be/tKjBFuHCkM0
    • By Rich1028
      Video from last Saturday on the Denton Trails...PONDS!
