    • By Adamb2025
    • By Atomusthenes
    • By worldmotocentro
      FOR SALE : YAMAHA 300 HP 4 STROKE
      Purchase your choice of quality outboard engines at affordable prices
      New & Used Outboard Motors (2-Stroke and 4-Stroke)
      Brands: Yamaha, Honda, Evinrude E-TEC, Mercury, Suzuki, Tohatsu Jet Skis, Sailboats, Powerboats, Watercraft, and Snowmobiles
      For Inquiries, Contact Us:
      Whatsapp Text: +1 (217) 460-7668
      Email: [email protected]
      Brand: Yamaha Motor, Yamaha Motor
      Weight: 229 kg (505 lbs)
      Manufacturer Item Number: Lf300xca
      Inbox if you're interested
      Contact for Purchase.
      Whatsapp Chat Number: +1 (217) 460-7668
      Unleash the ultimate performance on the water with Yamaha’s 300 HP 4-Stroke Outboard – built for speed, strength, and reliability.
      ✅ Unmatched Power: Smooth, responsive acceleration with 300 horsepower at your command.
      ✅ Fuel Efficiency: Advanced 4-stroke technology gives you more time on the water, less at the pump.
      ✅ Quiet & Smooth Ride: Yamaha’s cutting-edge engineering delivers powerful performance without the noise.
      ✅ Built to Last: Rugged design and legendary Yamaha reliability keep you running season after season.
      ✅ Smart Technology: Integrated digital controls and monitoring for precision handling.
      Whether you’re chasing fish offshore or enjoying high-speed runs, the Yamaha 300 HP 4-Stroke is engineered to take you further, faster, and stronger.
      ⚓ Yamaha – Reliability Starts Here.
      📞 Contact us today for pricing, availability, and special promotions!
      +12138024396
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
    • By dkgg5755
      Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
