Good morning!
I have a 1999 Yamaha Big Bear 350 4X4 and I need to rebuild the carb. I have the dual-cable throttle model and I'm having a terrible time finding the correct kit for it. I'm not opposed to replacing it, but the only ones I'm seeing do not have the dual cable throttle system. Any help would be greatly appreciated.
Thanks,
Jay in WI
P.S. I can send pictures if necessary.
I'm not sure the similarities between the single and double cable carbs enough to say if one rebuild kit will fit another.  I do know though that the only thing i ever use in a rebuild kit is the needle valve and seals.  So if the bowl gasket looks the same for a single cable carb I would think you'd be about good to go.
Most of those I run across have already been fitted with a single cable carb.
    • By Atomusthenes
    • By Tim Keiper
    • By Thumpinhard25
