Similar Topics
By Abbeypalm
While cruising, my 2011 750 king quad suddenly shut down. As it happened, red lights on the display flashed. Any ideas? My head lights suddenly stopped working about a week ago, if that helps. I have no power at all. Thanks
By Brennon Heflin
So I bought a 2000 quad runner 250. I'm having some issues an wondering what it could be I replaced the pet cock valve an the fuel filter an pump inside tank I also put a voltage regulator on it. The problem I'm having is that when u give it half or more throttle it bogs down an loses power what could it be the bike is almost like new an cant figure it out any help would be great
By Randel1
I'm having a problem getting a CDI unit that works. The parts list calls for a 4XE-85540-00-00 CDI unit. The one currently on the ATV works but there seems to be a problem with the spark advance curve. It will idle fine an rev. to about 1.5K then starts bogging down sputtering, popping and basically running poorly. If you can get it above 2200 RPM it runs better. I have ordered and returned about 5 replacement modules that will not work at all. The unit currently on the bike has no part numbers or identification other than a Mitisibuchi logo. I am wondering if anyone else has experienced similar problems with replacement CDI's and if so what is the fix? So far I have not found a replacement CDI that will supply an pulse to the Ignition coil.
By smitht18
Looking for the rectifier. Most bikes have near magneto. It appears the KQ has it in front.
Can someone tell me exactly where it is?
Bike not charging and magneto checks out ok
By Hunter19
How are you doing guys I just joined I have a 1998 Suzuki King quad I’m having problems with high RPMs the ATV idols perfectly but soon as a throttle up it doesn’t stall but it just bogs down it has no power any suggestions thanks
