1998 Arctic Cat 300 won't run right after warmed up
By kevinohio
By tepin
By kevinohio
By kevinohio
My cylinder is full of gas.i thought if carb was messed up.gas came out the overflow.had a cheap china made carburator on it.i ordered a factory used one.couldnt find a new one.also the fuel shut off isn't working right.and going to be needing the battery hold down and seat bracket.where can I get a used one?
By ButchM
