By Eisenmatt17803
Good Morning!
Has anyone had a problem with the small aluminum 90 degree elbow popping out of the valve cover and blowing oil all over the place? It looks like it is simply pressed in and will most certainly repeat the offense. Any experience you all can share with this issue?
Thanks in advance.
By kawasig
Hello there
By Asand211
I've got a 1995 220 Bayou and the electric start does not work. When I got it the machine was pretty rough but I was told it ran less than a year ago. The key switch had been cut off and wires twisted after the key was lost. I bought a new ignition switch and repaired the wiring and it is working correctly. It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button. I verified there is no voltage going to the starter from the solenoid. The fuse in the solenoid is good. Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on. That doesn't make sense to me but I could be wrong. I would appreciate any help I can get. Thank you in advance.
By DexKing
When you and a group of friends decide you want to take a long group trip of camping/riding/overlanding, how far are you willing to drive for your trip? Right now, i find it really difficult to want to drive more than 2-3 hours one way.
