I have a 1999 LT500F quad. When you hit the throttle it won't rev up and back fires. The weird issue is when you hit the starter button the engine revs up perfect??? Is this a wiring, surge issue or part malfunction?? Any help or recommendations will be greatly appreciated. Thanks
It will be a problem with the charging, the regulator operation in particular. If you turn the headlights on you will probably find it makes it slightly better too.
Check your battery and charging.
    • By Thekevinjb
      thanks
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
