What are best tips to clean your quad from the Oregon clay/mud?
By jay41198
By kevinohio
By RussB
Can anyone in the group give the dimensions of this washer. ID-OD and thickness. Dealer says they are backordered til 5-26. Don't want to wait that long. They are less than 2 bucks apiece and i need 4. Thanks
By tcd
Ok recently got a "what i believe" is a 2003 rancher 4x4. I believe it is a 350te. Obviously a project. Wire harness was in bad shape.
Reconnecting wiring harness. Have one harness that does not match...... the end or front side of the harness has this harness. .... appears to be the one that connects to the dash./ LED indicators... The only wires (indicators) that I can find that does not have a match to the main harness connection. These 2 harnesses do not appear to go together . it appear the harness or dash cluster were changed and don't match. Dash/indicator light wire harness was cut off. Attaching pics of both connections. Is there a way to make this work or do I need to buy a new harness or cluster?
