Lay it flat, use a spray bottle with about 10% dawn dishsoap and water.
Spray genrously and let sit.
If the tires have been on the rim for awhile it's going to take some effort.
You might want to go around the rim with a deadblow (plastic) hammer or similar to start breaking the bead seal.
You can lay a 1x4 over the rim where your working to keep from smacking your rim.
Your going to have to do both sides.
Do both sides First.
I usually lay a piece of plywood down under a manual bead breaker.
Just makes it more stable and less likely to damage something.
Make sure you take your valve core is out of the stem too.
Break both beads first.
If the bead breaker doesnt work there are other methods to break a bead seal, but they start getting kind of sketchy.
Most rims are designed to pull the outer bead over the front side first, then the inner bead over the front/outside.
You can tell by the softer (often narrower) radius near the rim seat.
You can find rim protectors that slip onto the edge of the rim.
I would seriously suggest using them unless you hate your rims.
Or you can use vinyl edge trim thats wide enough to slip over the edge of the rim.
THREE tire spoons, not two. Trust me. THREE SPOONS.
You get one in (small bites), get your second one in then use your third spoon to lock it into place.
Stic it in as close as you can, swing it over the second spoon and hold it with your knee.
Then you leap frog the first spoon and take another small bite.
If you take too big of a bite, you will just undo everything you already did.
Repeat.
Once your about halfway you will feel the pressure ease and might be able to just pull it by hand the rest of the way.
Locking the spoons with a third lever helps prevent getting slapped in the face.
(I made a custom set of 36" ones)
The shorter your sidewall in relation to your rim, the more of a fight your in for.
Once you get the tire off wash your rim, and scrub the bead seat on the rim.
Steel wool on a steel rim is fine but use a plastic scrubby on Aluminum.
On a steel rim you can knock the rust down with mid to fine sandpaper.
Your just knocking rust off, not trying to polish it.
DONT sand aluminum ones.
Good time to look for cracks, pitted metal on aluminum or cracking welds on steel rims.
My solution now is to be grateful I DON'T have to hand change tires routinely like I used to.
At one point I could do a truck tire off and back on in about 15 minutes.
ps, the dots/circles on the tires are alignment indicators.
Edited by Ulfthednar
Good rundown Ulf. The only thing I'd add is that when you have broken both beads and driven them into the smaller diameter center of the rim, and are about to start levering one side of the tyre out and over the rim, you have to hold the opposite side of that same bead down into that smaller diameter center of the rim. The tyre won't stretch enough to come over the rim if the opposite side of the bead is out near the bead seat, but if it's in towards the center of the width of the rim the tyre it can move towards where you are levering, and is long enough to lift off on one side.
The first time I tried to change a set of atv tires would have made a good fail video. Breaking the bead kicked my butt. Beat on sprayed em, kicked em, cussed em, took em to work and tried to use the backhoe bucket. Gave up and took them to a shop and they broke em loose for me. I think they'd been on it since new. 10 or 15 years probably.
It's because of what I say King..  They only fit over the rim if the opposite side of the bead is pulled right into that smaller diameter bit near the center of the rim width.. And..  it pays to keep rechecking that the opposite side is right near the side you are working on but in the center depression. as you are levering tyres on or off..  To get the new ones on you push one bead on till it hooks into that center depression, then start levering the bead on the other side of that same bead, but you keep checking where the bead in the depression is.. The first side of the tyre can be pushed right onto the rim by hand if it's lubricated..
I've been fitting bike tyres with a single six inch lever for ever..  Done right, we can push the first side of the tyre right on by hand, then fit a tube, and then fit the seconds side with a single lever if we do it right.. Tyres do not need stretching, only positioning in/on the rim correctly.
All tyres and rims, except split rims, work like that.. There is no need to stretch tyres !!
Edited by Mech
Yeah.. And I realized that neither of us has mentioned.... there is generally one narrow side and one wide side of the rim, measured between the center depression and the bead seat..  Always take tyres off on the narrow side.
And, you have to have all you can of the bead sunk into that center depression while you are pulling one short bit of the bead over the rim. If you sink the bead in, then apply a little pressure with a lever on the opposite side of the bead, you can generally push more of the bead into the depression as it pulls in.
I am a big fan of doing everything for myself, I also have one of the harbour freight tire changers, and I have done it , but not very efficiently, I decided years ago that was a job I didn't enjoy and was best left to the guys with the right equipment, money well spent. IF you buy your tires from them they will mount them for free, lesson learned.
  • 2 years later...
Had to change 'Granpa's' 4.00/4.8 x 8 in gravely tires.  The tire would not come off. I beat on it for 3 hours! finally running out of cuss words (and Lent starts tomorrow) I cut the tires loose and used my propane smoke wrench.  After burning out an area i could cut the wires  at the inside diameter of the tire.  Ok Ok I know I am going to get a lot of push back but I was desperate.
burnrim.thumb.jpg.5338adc7c4178fcab32a6e21d0f8a0c1.jpgburnd.thumb.jpg.1ca512219a5c338c90663aa0f6bac3fc.jpgburnwires.thumb.jpg.9b9496513c64429553c8caf8c2e5c29c.jpg
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By treycotiii
      Looking for the best options. I primarily use the machine for snow removal and yard cart pulling.
      I have had my new tires for a while, chronic procrastinator, decided it was time to get them mounted up. Against my better judgement i decided to mount them myself.
      I got one of these Harbour Freight manual tire mounting machines, mounted it to a half pallet to make it more portable. Very impressed with the quality and amount of tools that came in the kit for a low price point.
      The bead breaker worked very well, i wasnt sure it would be able to do it, i think these tires are original to the bike its a 2004, but with enough lube, mothers concentrated car wash straight, it finally broke the bead.
      Tire fit very well on the machine and it tightened down good.
      The extra long pry bar that came with the kit worked well to get the outer rim of tire off.
      Half way there, half way there no issues, then it got serious.
      I pulled and i tugged had 3 prybars working this thing and it wouldnt budge no matter what i tried it would not come off, until i got the grinder out and cut it off. Im sure most of you see what the problem was. I didnt notice it until i was too far in to change direction. On this particular rim the tire goes on and off from the back side of the rim, not the front like what i was used to. The back side is the low side. Plus to add to the problem tires were old and not very strechy, i have a greater respect for how well these ATV tires are made with well reinforced sidewalls, even with the grinder it took me a minute or two to cut through it, of couse i was being very careful not to nick the rim. Anyway the HF machine worked well and the tire is off, hopefully the next one wont be this bad. Lot of hard work for an old man, glad i can still do it.
      Now for the fun part , cleaning up the old rim, years of stop leak and slime caked on the inside, that stuff dries hard, the little Milwaukee is good for getting into tight spaces, but wasnt quite up to the task.
      Needed a few more RPMs.
      Old rattlecan paint just flaked right off. Now time to decide on a new color, tired of the boring gray. More to come!
