I just purchased a new kymco 270, and I absolutely love it. I was reading about the break in procedure, and thought it was overly cautious, but then I got to thinking and the reason they are so cautious is the carburetor is too lean because of emissions. I am in california and our smog laws are the worst. first thing I did was remove the cap that prevents you from adjusting the idle mixture, and that made starting much easier, I don't even need the choke. then I changed the 108 main jet to a 115 and it really runs a lot better. the carburetor is easy to work on, you don't even have to take it off, it can be twisted enough to reach everything pretty easily. the idle mixture screw is not slotted, but I was able to adjust it with a pair of tweezers. the dealer made the changes to the transmission  for me, so all I had to do was screw out the throttle limiter, and this quad runs great. I have tendonitis and the thumb throttle bothered my wrist, so I put a twist throttle on it.  other than that, I plan on keeping it stock, it does everything I could want.
Thats interesting Kei Hins are generally tuned perfectly from the factory, maybe because of the snog requirments  they put on these days make them a little leaner, my only concern might be how does it run at high speed and warmed up. Sounds like you have it figured out, but 115 is a fairly large jet for a 270, but if it works good thats all that matters. Thanks for sharing your reasearch.
    • By wilmpie
      hi everybody
      thanx in advance
      Hello there
    • By Olchap
      Hi, I am new to  this forum and I am happy to be here.  I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is.  I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing.  I checked up near the radiator and found nothing.  Where else should I look?  See image below.
    • By Rickm59
      I have a 2022 Kymco MXU150 and have been trying to bleed the rear brakes for several days. I have used a vacuum and also tried the lever pumping. i took the caliper off and compressed the piston with a C clamp and had a tight brake lever. I put it back together and still cannot build any pressure in the brake system. Any ideas from anyone?  Thank you
    • By gwares
      Price : 4500 EUR
      The Kymco CV3 is a pioneering three-wheeled maxi-scooter that combines the agility of a motorcycle with the stability of a trike, catering to riders seeking versatility and performance. This can be ridden on a car license!
      Key Specifications:
      Engine: 550.4 cc parallel-twin, liquid-cooled
      Power: 51 bhp (38.1 kW)
      Transmission: Continuously Variable Transmission (CVT)
      Fuel Tank Capacity: 15.5 litres
      Seat Height: 795 mm
      Dry Weight: Approximately 280 kg
      Brakes: Dual front discs and single rear disc, equipped with ABS
      Suspension: Independent front suspension with dual leaning wheels; rear mono-shock
      Wheels: Front: 13-inch; Rear: 15-inch
      Everything works and new!
      We try to capture everything in photos for you.
      If you have any questions or need other photos, just ask, thanks.
      Send a direct message to make an inquiry or text:
      WhatsApp: +33 758 56 21 59
