By wilmpie
hi everybody
I have a kymco mxu 250 automatic from 2006 250 cc that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
thanx in advance
By kawasig
Hello there
By Olchap
Hi, I am new to this forum and I am happy to be here. I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is. I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing. I checked up near the radiator and found nothing. Where else should I look? See image below.
By Rickm59
I have a 2022 Kymco MXU150 and have been trying to bleed the rear brakes for several days. I have used a vacuum and also tried the lever pumping. i took the caliper off and compressed the piston with a C clamp and had a tight brake lever. I put it back together and still cannot build any pressure in the brake system. Any ideas from anyone? Thank you
By gwares
Price : 4500 EUR
The Kymco CV3 is a pioneering three-wheeled maxi-scooter that combines the agility of a motorcycle with the stability of a trike, catering to riders seeking versatility and performance. This can be ridden on a car license!
Key Specifications:
Engine: 550.4 cc parallel-twin, liquid-cooled
Power: 51 bhp (38.1 kW)
Transmission: Continuously Variable Transmission (CVT)
Fuel Tank Capacity: 15.5 litres
Seat Height: 795 mm
Dry Weight: Approximately 280 kg
Brakes: Dual front discs and single rear disc, equipped with ABS
Suspension: Independent front suspension with dual leaning wheels; rear mono-shock
Wheels: Front: 13-inch; Rear: 15-inch
Everything works and new!
We try to capture everything in photos for you.
If you have any questions or need other photos, just ask, thanks.
Send a direct message to make an inquiry or text:
WhatsApp: +33 758 56 21 59
