Bought 95 Bayou 300 - Need Help
Similar Topics
By Atvguy0901
Thank for the add on quad crazy. I am new here and need some help with my atv. It’s a older Yamaha Timberwolf 250 that I purchased second hand from an person. I got it home ans started to look into it. He stated it needed a cdi box so I ordered one for it and a battery as well also a key switch cause it did not come with one. I put all the parts on it and when I hit the start button it just clicks and noting else. Thank you any help is appreciated.
By Params_sweden
Hi, I have an EU '94 KLF300 Bayou with ignition issues. I got it last summer and used it for about 20 hours, then one sunny day we used it for about an hour, parked it, and then it didn't want to start again. It has a *really* weak spark, I've only been able to see it once while testing.
I'm just getting started on this, I'm going to go through all the weak/no spark trouble shootings from the manual. Since I've already invested like 10 hours digesting the manual and forum threads that I possibly can, I thought that it would be nice to create a thread like this in case I come up with a solution that can help someone else.
So far I've replaced the spark plug, I will replace the spark plug cap with a NGK VD05F (5kOhm resistance). I'm going to check the resistance in the pickup coil, stator coil and ignition coil next. I have tried two CDIs, right now I mounted the original CDI which actually gave the most output to the spark plug out of the two
A question for you, is it possible to make any assumptions about the CDI by measuring the resistance like in the manual? There's a "resistance table" that you can refer to when measuring between the different connections. I'm asking because I haven't yet seen anyone in the forums that has mentioned that they've measured the CDI resistances and made any conclusions from that.
I'll attach a photo of my Bayou
Pär, Sweden
By Yourmanyoshi
I have a kawasaki klf 300b 1987 and when i got it originally from a friend it was sitting for like 10 years and of course it didn't run so i went through the steps of fixing it. Had good compression and clean carb but i wasnt getting any spark. I went through the steps of fixing that and turns out the cdi box was bad, so i replaced that and got spark so i started her up and she was a little scared at first but slowly broke in and idled perfectly fine. But everytime i gave it any gas it would just bog out completely so i had it idling and sprayed starter fluid into the intake to see if it would rev up, but it did the opposite and died out. I think it might be something to do with the spark since after that i took it out and it was wet. Im guessing its not sparking at higher rpms but i have no idea how to fix that since ive never had that issue before, keep in mind ive cleaned the carb maybe 5 different times with a supersonic cleaner and put needles through all the wholes. Someone please help me out with this old *** atv
By Ajmboy
This service manual is for a 1986-2006 Kawasaki Bayou 300.
Adding to downloads library.
By Jim Denton
I was gifted four King Quad 300's, they were used to tow portable snow guns around the slopes. All of the plastics are trashed and racks bent up from rolling down the mountain. The lone Quadrunner is a 98, and will be the initial point of focus, as it reportedly ran before being parked in the field of lost dreams.
Gallery Images
