I was doing some long overdue maintenance on the ATV today and found that the rear seal on the front differential is leaking a fair amount.  Has anyone ever replaced one of these?  Do you have to pull the axles or can you just pull the differential forward and drop the driveshaft out of it?  I wasn't able to find much on this in forums or YouTube; most of it talks about changing out the axle seals.
Any advise, tips or tricks would be appreciated.
    • By toe420
    • By DexKing
      Good day everyone!
      I am pretty new to ATV/UTV/Small engine repairs and would like input on your absolute must-have specialty tools for maintenance and repairs. Aside from the obvious wrenches and sockets, what are some more specialty type tools you use for troubleshooting? I don't plan to open a repair shop or anything, I just do this as a hobby. Looking forward to your responses!
    • By TomJulio
    • By LCP92
