2006 rancher 350 Trx350te will not shift with electric shifter or with the manual emergency shifter. Could something in the electric shifter stop the manual shifter from shifting also? Should I start there? Thanks for any help.
Was the engine running or were you rocking the bike back and forwards, as you tried shifting with the manual shifter ?
They generally won't change gear manually if the engines turned off unless you rock them.
To diagnose what's wrong with the electric shift you need to download the service manual and have a read, and then start following the diagnostic process they lay out. An early check is to see if the dash is flashing at you, and then to read the stored trouble codes which give an indication of which bit isn't operating correctly. Then you check the indicated bit, and it's wiring, and all and any bit's indicated as not operating correctly, before deciding which bit is the cause and which are not operating correctly as a result.
  • Thanks 1
    • By wanrep
    • By wanrep
      YFZ05YYXH
      YF05RH
    • By Tinkeringreg
