Just bought a cheap moto4. Runs and rides great in low and high. Issue comes with trying reverse. Everything I read says foot brake on and in 1st gear. Then pull back into reverse. Nope. Not mine. I removed the safety wire on the brake because it wasn’t moving. Same issue without it. I put the quad into neutral and pulled hard and bam…..goes into reverse!! Then I stop and try to get into forwards and no luck. Stuck In reverse. Turn it off and try and the lever moves into low high and back down with ease. Start it up and same thing. Would really love some help with this one. Thanks in advance!
 Sometimes the shifter gets corroded under the rubber boot and doesnt want to move fluidly, and the little metal tab doesnt clear the locking mechanism to make the shifter move, don't know if that's what's happening with yours, but its something to check.
I've read about jammed up interlocks and broken springs in them.. I think I'd disconnect the cables and try operating things by hand down on the engine..
I've been looking for a manual.. apparently those old ones(pre 87) are called YMF350ER, ERT, ERW, ERA or ERU ? Sound right Alley ?
The YMF350F series models service manuals are easy to find, but not the ER series..  If anyone spots one..
Edited by Mech
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Jdeaton011989
    • By KIWINZ
      Hello
      My son scored a free Moto4 - late 80s from the looks of it. I don't know anything else about its history as the owner wasn't there when i picked it up. Can't see the VIN number as its a bit rusty.  He cleaned the carb and then with some either it started and still starts first pull.  Its runs really nice - not rattles etc.  Goes forwards well and the brakes work fine so it looks like a keeper, However, we have only managed to get it into reverse once.
      1) it won't shift down into what seems like where first would be - 2nd and upwards only. The changes between gears is fine.  No crunching or missed gears - just no first gear.  2nd gears appears to be as low as it will go
      2) the clutch - when you hold the gear lever up or down works (only the second ATV we have had.  Other is a Quadrunner which doesn't have this feature)
      3) no neutral light - will start when no in neutral - should it do that?
      4) the one time we did get it into reverse the neutral and then the red (reverse) lights worked. Swapped easy between forward and reverse - when it went into second, it didn't return to first or neutral
      5) checked the clutch adjust on the RHS - seemed fine to me.  When i turned the screw back 1/8 it was where it was to start with.  Clutch doesn't slip.  The bike will move forward is all gears.
      Any help would be appreciated
      Andrew
    • By vaneleus
    • By gordonmacritchie
      all fuses are fine
