By Mikey509
Hi guys, I was given a 2000 Honda Recon fourtrax 250 (I think that's the full name lol). The previous owner had it sitting for a while before I got it. It sat for another few years in my ownership. I got it up and going on its first test drive today!! I was wondering where everyone buys their parts from? Coming from the car community, we have sites like RockAuto and many more. Anything like that for quads? Also would like to be pointed in a direction, if possible, for plastics. I am missing a few and would like to have it complete. I appreciate any input!
By quadcrazy
Trail System Deep Dive
Final Thoughts
Visit Pine Mountain ATV Park
By Zrach
I wanted to share a successful workaround for a "no-spark" issue on a 2009 LT-A400.
This is specifically for cases where the CDI has been diagnosed as faulty, but the age or condition of the machine makes the cost of a brand-new OEM unit hard to justify.
Note: This modification compromises the factory “no-start” circuits.
On some malfunctioning CDI units the internally damaged circuitry is only partial.
Feeding full time power to the Parking Brake pin, the unit is triggered to bypass the internal fault and produce a healthy consistent output to the Ignition coil.
The Modification
See the second diagram attached below for the wiring specifics.
The Result:
The machine has clocked over 1,000km since this repair and is still running strong with no ignition dropouts.
⚠️ IMPORTANT SAFETY WARNING ⚠️
Please be aware that this modification compromises the factory safety "no-start" circuits.
The machine will now start in gear. The safety interlock involving the handbrake is no longer functional. The machine can move unexpectedly if the starter is pressed while in gear. Proceed at your own risk. If you sell the machine or let others ride it, ensure they are fully aware that these factory safety buffers have been removed.
Faulty CDI Workaround.pdf
By mikeexplorer
