Oil filter cover leak and oil draining 2021 TRX520
Go to solution Solved by wanrep,
Sorry, bit of newbie question on Honda TRX520
Can anyone tell me if it is necessary to drain the engine oil to just remove the oil filter cover?
I recently carried out an oil change and when checking afterwards, found oil leaking from around the oil filter cover (was torqued to 10Nm). I am going to get new O rings to be on the safe side, but was wondering how high the oil level in the engine sits relative to the pump filter and do I have to drain the oil?
TIA
Nigel
Edited by nblain
Adding model details
  • nblain changed the title to Oil filter cover leak and oil draining 2021 TRX520
    • By Atomusthenes
    • By Tim Keiper
    • By BigJohn85344
      Hi! I’m new to the forum. I have several Polaris Trailboss 500’s, which I’m trying to make 2 usable bikes from. One is all but complete, needing only reassembly, while the other two are a decision as to which is parts and which is bike. lol. Anyhow…
