  • Admin changed the title to 2003 Yamaha Kodiak 400 Neutral Safety Switch
A defective neutral light won't stop the power supply to the bike, it only stops the start system working, and, you can over-ride the start safety inhibit by pulling the left brake lever on I'm pretty sure.
Have you checked the fuse ? Do the lights or horn work ?
The neutral wire usually connects to the switch on the left side of the engine. It’s usually under the shifter but this is automatic I believe. I’m still assuming it’s in the same place.
    • By Atomusthenes
    • By Tim Keiper
    • By Travis_Smith
