Regards
  • Solution
I'd suspect that "auto" is really a variable ratio/diameter set of pulleys and a belt. One of the pulleys will either be moving apart  to the shrink the effective pulley diameter, or, not separating when it is meant to be separating, and so causing the high revs and no top speed.
The struggling up hill might correct itself if you fix the pulley problem. Does the engine seem to have full power when it accelerates away from a standstill, or perhaps at mid speed it might perhaps to have full power ? If it seems to have full power at some speeds (the speeds the ratio it's stuck in suits), and if it isn't actually missing uphill, then I'd concentrat5e on getting the belt drive cured.
No it seems to pull away slowly than I would suspect also when it is struggling uphill I can release the throttle almost half way before the speed drops anymore ,
Sorry for late reply only just found your message
Paul
It sounds like the variable ratio belt drive system is playing up. You aren't mentioning missing or backfiring or cutting out or anything that suggests the engine isn't running fine, and those symptoms could be caused by the bike being stuck in a high ratio.. I'd look there first..
    • By HoldenBoy
    • By TomJulio
    • By kevinohio
    • By Adamb2025
