ATV Drag Racing Association : Index
Professional Classes
$100.00 Entry
· TOP ALCOHOL
1. Snowmo & Motorcycle Powered
2. “RUN WHATCHA BRUNG”
· TOP FUEL
2. No Power Adders
· Pro Mod
1. 102mm Center to Center
2. Power Adders Permitted
· Super Comp
1. Aftermarket Cylinders
2. Up to +14mm stroke
3. No Power Adders
· Pro Street
1. Cub Cylinders
2. Up to +8mm stroke
3. No Power Adders
· Super Street
1. Stock Cylinders
2. Up to +4mm Stroke
3. No Power Adders
Sportsman Classes
$75.00 Entry
· Super Eliminator
1. 4 Stroke ATV Engine
· Super Sport
2. No Power Adders
· Pro Stock
1. Single Cylinder 2 Stroke
· Super Stock
2. No Power Adders
· True Street
1. Stock Engine & Stock Suspension
2. Bolt on Performance ONLY
3. NO Out of Frame Drag Pipes
4. Factory Style Tires
· Pro Redneck
4X4 No Power Adders
Index & E.T. Classes
$50.00 Entry
· Outlaw *5.90 Index
· Pro Gas *6.40 Index
· Top Gas *6.90 Index
· Super Gas *7.40 Index
· E.T. Class *No Boxes
GRUDGE CLASSES
$50.00
Flagman Start, NO TIMING SYSTEM USED
· STREET FIGHTER
1. Power Adders Permitted
· REAL STREET
2. No Power Adders
***Fastest Man on Asphalt***
$1,000.00
*All Classes are required to have a minimum of 8 quad entries to receive 1st and 2nd place payouts split in a 70%-30% amount of all entries paid. Any classes that do not have the minimum required entries will be paid on a 1st place winner takes all basis. *All classes are required to have a minimum of 4 quad entries for the particular class to be held. *Any racers that do not have a competitive class offered to them due to requirements may join and vote for additional classes to be added, class additions will be judged on a majority rules basis. *In order for a racer to receive title and prize for the “Fastest Man on Asphalt” must make a full pass with times posted and perform a pass with a lower E.T. than past records set. *The 2008 record to beat for Fastest Man on Asphalt is 5.67 seconds in the 1/8 mile.
WICKED WEEKEND 2007 VIDEO
[ame=http://www.youtube.com/watch?v=nyM5Vi1-Q7k]YouTube - Wicked Weekend 3 - www.Wickedatv.com[/ame]
    • By Dsluder
    • By buriedpast
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By ButchM
