1998 Kawasaki Bayou 400 4x4 Electrical Issue (Neutral light intermittently turns on and off)
By cavry
O3 sat a while. Engine is running fine. I got it into neutral, did some general tune-up and cleaning then pulled the shifter pedal up and it locked up and will not release into neutral again. Does anyone have experience with this problem? Thanks for looking and any help.
Cavry
By realpilot
By OldATVowner
By Dsluder
By flyinbrian365
What's Covered:
