26 minutes ago, jen said:
Hmmmm...I wonder if they make a Siamese connector so I can leave the ciggy connector also????
It's not hard to add any type of connector you want  or to make adapters to switch between them.  ie: a ciggy plug (as you call it)  to  an  SAE or an SAE to a  "ciggy plug".
    • By joezee13
    • By middlebrookgt
      Interesting Jumper Pack. No battery to die and works well. It is basically a string of capacitors that takes the minimun voltage that is in your battery , even though its not enough to start the machine, it is enough to fill the capacitors and boost the battery for starting. The only problem is if the battery is completely dead wont do any good, but you can charge it in 2 minutes with your car battery. Interesting idea if the capacitors hold up, time will tell.
    • By Ejwill
