I have about 5 days until my next race. This one will be a 130 mile race in the heat of the day July 11th. The riders will have 2 challenges, ride hard an smart to take the right line and keep their machine from overheating. It is supposed to be about 97 degrees.
I'm currently 4th in the points standing, the number 1 rider is unable to race and he is prepping my quad for me. I think I see a top 3 performance...if I can finish!
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
    • By BillR94
      Thank you for your time
      Bill
    • By BruinBeater
      Got asked to take a look at a 2014 Can Am Commander 1000 for an overheating issue.  Owner says he's been having issues for awhile.  Had another guy put a new electric fan on it and its still overheating.
      I take it for a test drive.  1 mile on asphalt and temp gauge is pegged and machine is telling me its overheating.
      Looking at it in the garage and I see, it low on coolant.  As in, the overflow tank is empty.  Can't see it in the radiator.  Not sure how far down it is.
      Took out the seat, and center console. I see coolant on top of both cylinders.  Its leaking a tiny bit from each coolant outlet on top of the cylinders.  They are plastic with a metal bleeder screw.  Both leaking from the bleeder screw.  Tried to tighten them but I can tell they are stripped out.
      Bought some aftermarket coolant outlets from Quad Logic.  They came with a new bleeder screw and crush washer for the screw.  They did not come with a new gasket.
      Bought a new OEM thermostat.  Did it really need one?  I'm not sure, I didn't bother to test it.  Its not a cheap part but not terribly expensive either.  These commanders are a pain to bleed all the air out of the cooling system, I only wanted to do it once.
      Remove the plastic screen from the firewall so I can access the thermostat.  Cut all the old hose clamps off (OEM Crimps) Replace the T-stat.  Install new hose clamps.  Install new coolant outlets on top of both cylinders.
      Now its time to bleed the system.  I have a "NO SPILL FUNNEL"  Remove the radiator cap and attach this in its place.  Fill the funnel up about half way and let it sit for awhile with the bleed screws open.  Once I see fluid out the bleeders, I close them.  Squeeze the hoses a bit and watch the air bubble come up into the funnel.  Once the system is full, I drive it to a hill in the yard and put 1 car ramp in the middle of the hill.  I drive up the car ramp with the left/drivers side tire.  This puts the radiator cap up nice and high.  Let the engine run for as long as it takes to get the air out.  I keep the full at least 1/3 full.  I rev the engine to 4K rpm.  I jump out and squeeze the upper rad hose, the lower rad hose, and both lines to the cab heater (aftermaket) I keep doing this till I no longer see air.  I also crack the bleed screws loose on top of the heads during this time.  The fan cycled on and off multiple times. It took approximately 45 minutes till no more bubbles were coming up into the funnel.
      Remove the no spill funnel and top off the recovery tank with the coolant trapped in the funnel.  Took it for test run up the road and hit a little trail.  Outside air temp was 92F and 90% + humidity.  Machine never came close to overheating on the ride.
    • By DAVIDH
      Hello my name is David, I have been riding for over 30 years ATV, dirt bikes, S x S you name it. I ride with a small group off and on though out the years. Currently, we have only three of us that have been riding this year and we are looking for more people to join us!
      If you're in the Northern California area and looking for people to join on weekend and day trip rides send me an email: [email protected]! We have been to many OHV sites all over the state and we usually try to meet up for a ride once a month.
      I look forward to hearing from you!
    • By wjmedic
      Recently rebuilt front end on this Polaris 400. New axles, bearings, seals, control arm bushings, Hilliard clutch thoroughly cleaned and inspected with no damage noted.
      Everything put back to together. Placed bike on jack stands all four wheels off the ground, started in 2 WD switched to AWD both front tires spinning, when AWD turned
      off right front wheel will not disengage from AWD. Checked voltage at connectors both left and right connectors have no voltage with AWD switch off, and both have 12.4V
      when AWD switch is turned on. Repeated turning switch on and off several times with no change in condition. I am thinking this must be something mechanical with the
      Hilliard clutch on the right hub ie. weak spring or stuck rollers on the Hilliard clutch assembly (Is this a logical thought?) any ideas on trouble shooting this before I disassemble the
      right front hub again
