Guest Fox300exchic
There are many ways to install grips and make them stick. The best one, short of having grip glue, is to use carb cleaner. First, clean your handlebars with carb cleaner and a rag, then spray the inside of the grips liberally. The carb spray acts as a lubricant first and then actually melts the grips enough so that it will bond to the clean handlebar. This works great for all but the most extreme conditions. If wet weather is involved, you really need to use grip glue, and in addition, you should follow that up with some safety wire.
QUAD off-road magazine
    • By jeffinotown
    • By Frank Angerano
