I just traded for this bike and do not know alot about it. It started fine when I look at althought it did seem to starter was having a little trouble turning the motor over. Now it just sounds like the starter is spining and it is not engaging. I took the cover off removed the starter torch limiter and the little gear behind it will spin very freely??? What does that mean? battery is not the strongest in the world either. Anyone have any ideas? I down loaded a manual so I have some idea of how its put together. Thanks.
    • By logray
    • By HoldenBoy
    • By crankin
    • By jen
      Cannot find out why 12 vdc  4 (4) commutator starter motor has no power. It will run full speed without load. But with any load will not turn. Repaired broken brush holder and insulated an internal wire to magnet that was bare and rubbing. cleaned commutator segments. Ohm readings while slowly rotating commutator was 1 ohm.   When attempting to run  with load it will not turn and Bat vdc only pulls down to12vdc. Cannot find an internal wiring schematic.  I can buy a rebuild kit ~$35 but WTH?
    • By joezee13
