OK,
my brother and now my brother inlaw and I all have a TRX250X
we picked up, not having alot of money to sink in them
what are some suggesttions?
like ive heard that 400ex front A arms will work on them but do you have to lengthen your tie rods?
some cheap mods? what carb to possibly upgrade to? ETC.
We have always built up cheaply since noi real budgets but i love riding so i want to keep up
better and have a better ride also
hell i out a 400EX rear shock on my old blaster it was amazing how much better it rode.
anyways anything would be great thanks.
The 400ex arms may fit, the only way to make sure is just measure both and see. The 400ex a-arms measure about 6 inches from the inner sides top and bottom, and about 9 1/8 in to the outer sides on top and 9 1/2 in on the bottom. If they do fit, they will be wider, so it would be best to use the tie rods of the 400 too. If they fit, the shocks will be too soft for the wider arms so you will want to do something about that. I would think that the 400ex shocks would be a bit long, but they may work. I would not bother with a carb upgrade before some other motor mods are done. First thing to do is find yourself a good exhuast, if you need to keep it super cheap, check ebay for some decent used pipes. A high flow intake, and modified airbox lid are cheap and easy. Just remember, with each upgrade, a jetting change is likely going to be needed.
    • By RadRob
    • By Trent Finnessey
    • By Dumass
