THE ORIGINAL OKEECHOBEE MUDFEST IS BACK: Presented by MUD LIFE MAGAZINE
By wilmpie
hi everybody
I have a kymco mxu 250 automatic from 2006 250 cc that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
thanx in advance
By harryjr
By Asand211
By TravisCr
I appreciate any suggestions- normally I'm a jeep and honda dirt bike guy- but I got a good deal on the quad and a plow so I went for it
By ATVNetwork
